Old 10-20-2007, 09:47 AM   #1
IHateHacks
IHateHacks's Avatar
Because they will bottom out if there is not a 2mm layer inbetween the 14mm allen head bolts and the cylinder head. You need to use either a new no.3 cylinder head cover or drain plug gaskets or you will strip the aluminum when you torque them to 13 ft/lbs.
