Old 10-14-2007, 03:32 AM   #1
kwnate
SP58GT
Disconnect the speedometer cable under the car, drain the fluid, remove the shifter, trans crossmember (and ground) exhaust hanger. You can disconnect the driveshaft in the middle and remove it or let it slip out as you pull the motor forward.
Nate
