Old 10-13-2007, 03:07 AM   #1
Jrew
Jrew's Avatar
Jrew is on a distinguished road
i was looking at pairing a clarion pxw1251/52 sub with a clarion dpx1800 amp. However, the 1251 is a dual 2ohm where as the 1252 is a dual 4 ohm. I want to pair it with the amp only if I can run it at 2 ohms but i didn't know if the amp could handle that. here are the links for both:
Sub- http://www.onlinecarstereo.com/CarAu...roductID=17464
Amp-
http://www.onlinecarstereo.com/CarAu...roductID=17289
Maybe I am incorrect however. Don't you wire the dual coil sub in series so that it equals 4 ohms? or can you wire it so that it is just 2? im slightly confused on that matter. Thanks for the info so far!!
If you're going to strive, strive to be the best.
Jrew is offline   Reply With Quote
