Old 10-12-2007, 05:23 AM   #1
f00g00
The dashboard could have been swapped too.
If you had a 5 speed swap then the check connecter on the supras with the A/T will be larger. Check the pic here and see if this matches yours and if so follow the instructions on how to pull the codes.
http://www.cygnusx1.net/Supra/Librar...aspx?S=AT&P=14
