Old 10-11-2007, 04:59 AM   #1
cyanide-is-a-way-out
cyanide-is-a-way-out is on a distinguished road
well i just found the idle screw like 20 mins ago and adjusted it but i didnt get this till after whats so bad if i adjusted it?? and also it idles and 650 now but the air fuel is wack cause where this one screw was sposed to go it get loose all the time and moves down on this rubber valve thing on the left side of the throttle boddy witch is like hooked into a fuel filter thing its like a clear thing it leads into u kno what thwe valve ios for and is it bad that i just adjusted the idle?
cyanide-is-a-way-out is offline   Reply With Quote
