Thread: 2jz swap
Old 10-04-2007, 02:13 PM   #2
supradaddy0803
supradaddy0803's Avatar
OK the major difference between the 1JZ and the 2JZ is .5 liter. the 2JZ is a 3.0 liter and the 1JZ is a 2.5 liter. Sounds major but really isnt. I have seen 1JZ's and 2JZ's push over 1200 hp. 600 hp is not that hard to acheive with either of them but the benifit of the 1JZ is that it comes from the factory with a metal head gasket already installed. It will handle 700+ at the wheels with no major internal mods. When you look at the motors side by side even people I show it to have to take a second glance. Oh and also the 1JZ starts at 280 hp and takes a little stuff like I have to get over 300 at the wheels. The 2JZ starts at 320hp and actually will net you about 270hp at the wheels to start. The big killer is that tranny and driveshaft will eat a lot of HP going to the back.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
