Thread: 2jz swap
Old 10-03-2007, 12:36 PM   #1
supradaddy0803
supradaddy0803's Avatar
Not to name drop or anything but there is a ton of people that have done them on supramania. If you go there and search for the 2JZ swap there has been a ton of posts about it. Also check here there are few people that have a 2JZ just a lot more work than doing a 1JZ swap and costs more. Sad most people dont realize that a 1JZ is the 2JZ little brother and has the same potential. Also the cost difference is a whole lot better like you pay 3 to 4 thousand for a 2JZ and like 1k to 2k for a 1JZ.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
