Old 09-28-2007, 08:51 PM   #1
808Supra
808Supra is on a distinguished road
Default mhm
Well The car also has a problem with the headlights staying on so when i sit the car i remove the (-) battery cable. and in the tsrm page FI-25 it states " cancellation can also be done by removing the battery (-) terminal," So effectivly i have been reseting the codes everytime i put her away for the nite. Im debating buying a new cps and ecu and rewiring the circuit with all new wires.
1989 7MGTE, auto.
Car has: 2mm steel HG, match port/polish on intake. Manual boost controller, Turbo Timer. Cold air intake/ intake heat shield, Pushing 12psi. Also the radiator system and all the rubber hosing on the car has been replace with new items.
808Supra is offline   Reply With Quote
