Old 09-28-2007, 04:23 AM   #14
Syris
Syris is on a distinguished road
Originally Posted by the ghoul
LOL
do tell how turbo lag adds low end power!!!!
Low end power is usually accomplished by higher compression…
The reason turbo engines have little to no lower end is because they are specifically made to keep compression low so you do not get pinging (pre-mature cylinder gas detonation).
You answered your own question. I wasnt trying to go into detail as to how an engine works with or without a turbo. I was merely stating the biggest difference between the two 7m's for general clarification as to why there is such the power difference.
Yay!! you understand that having different amounts of compression will result in how an engine will react.
If you can show me how I said Turbo Lag will result in low end power send me a pm otherwise stop being a troll, I was stating information for the cams and you come at me about compression and turbo's.
Syris is offline   Reply With Quote
