ignition mystery (what a surprise)
So i have this weird mystery (as perviously stated) in my ignition. It doesn't generate spark. I checked plugs, it has fresh wires, and the distributor doesn't have rust or scarring or anything strange (melted holes) that i can see on it. Its derinately timmed correctly (did it twice to make sure) and as far as i know the coil and computer were working. Now i'm poor so don't gun on me about the obvious tools needed for testing i know i need a multimeter but the one i have is a old hand me down from my old man ... its falling apart and its analog and its from like 1973 and i don't think it can handle the voltage being put out... i think the scale only goes up to 50 volts at highest. I'm pretty sure the computer is working because a lot of other components are working (efi main relay clicks, fuel pump relay clicks, the other relay in the passenger side kick panel clicks... really loud) and when i tested in the shop (at school which i'm no longer going to) it was fine. The coil was at a primary resistance of like 0.4ohms when its supposed to be like 0.26-0.3 so i figured it was ok for now. secondary was below maximum resistance. Perhaps my inexperience has left me screwed. So I can't get a real test from the multimeter i have. I do have qa cheap 12v test light that is brand new (i bought it so i might find out what's wrong) so while i know testing computers with a 12v is really bad, can i test the coil output or input with the test light without blowing up the test light? I'm open to some suggestions, laughs, whatever.
Its broke, it could be anything, and cost of repairs will greatly exceed the value of the car
