Thread: 7mge w/ tubro
Old 09-24-2007, 09:38 PM   #1
Supra2NR
Supra2NR's Avatar
Even if you get to use the hole on the otherside, how do plan to route the pipes?
Underneath the oil pan?
I'm not sure how much pressure there is in the return
But a slacked line causes oil to build up in the turbo, and causes it smoke and may lead to messing up the seals,
And that's only a slack on the line,
Jus tap the oil pan on the exhaust side of the engine, get sum fitting welded in
So that way ur sure its gonna work,
Rather than spending all that time routing lines to the other side, jus so u can blow ur turbo
