09-16-2007, 01:49 AM
#2
Supra Owner
Originally Posted by jdbones
Well, I fixed my dome light. First take off the plastic cover plate, then there are two screws that screw into to top, removed them and entire dome light falls right out. As soon as it did I saw the problem. There are a lot of wires in a small area and two of the wires, where they are soldered were touching. I unsoldered them, resoldered them and used some shrink tubing to avoid further contact. The lights work great. Delay off works, they work together or separately and work in the "door open" or off position. Congratulations to me. My cost $0.00 !!
Wow - first I've heard of this problem (and fwiw, that says a lot). THANK YOU FOR POSTING!!!
Life begins at 30psi.
