Old 09-12-2007, 05:33 AM   #4
west_side_supra
west_side_supra's Avatar
i dont know if those are adjustable or not, if it is loosen it up, if that doesnt work go to your auto store and pick up some white lithium grease and spray it inside the BOV and push the valve up and down, make sure its not sticking, cause i know my ssqv never worked untill i sprayed some lithium in there. so id recommend giveing that a try. other than that make sure you are useing a good vacume line.
7MGTE - 500hp never dyno'd
fidenza cam gears
