Thread: lighting issues
Old 09-06-2007, 08:41 PM   #2
All USDM MKIIIs came from the factory with a security system installed. I've seen it diagnosed as the reason for lighting issues as well (either due to a poor removal job or a fault in the unit). The main reason I'd check the security system is because it integrates with the retractor control/integration relay #2. If the security system was removed I'd go through and verify all the wiring modifications.
