Old 09-06-2007, 03:34 AM   #1
natedogg89supra
natedogg89supra is on a distinguished road
Originally Posted by dcrusupra
Well an ideal place to start is making the engine reliable. Is your check engine light on? Any vacuum leaks? Anything worn out excessively?
For upgrades, I would do exhaust and intake first. You don't really need a front mount unless you want that bling factor. The stocker is good for up to around 400 hp. If you get too big of an intercooler, your turbo will start to lag a good amount. A turbo timer would be good, they all work the same, so that will be personal preference.
As for the boost controller, don't go overboard on the stock turbo. 13 psi is all I would go. And thats on a healthy turbo. But there are a wide range of good boost controllers. I'd go with a manual boost controller to start with.
Any pics of your MKIII?
alright alright, thanks for the info...no pics yet gotta wait for the weekend than ill get some pics up as far as the check engine light...yes and vacuum leak im thinkin so not 100% sure yet
natedogg89supra is offline   Reply With Quote
