Old 09-06-2007, 02:10 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by 90lexus
...I was going to replace the heads and pistons, make my own intake, and get a new intake manifold, and from what i understand those are the only things that are different from the 2JZ-GTE and the 2JZ-GE...
Wrong...very wrong. There are MANY other differences, as detailed in many threads in this and other forums, as well as the original 'yota docs:
http://www.mkiv.com/specifications/ncf/ncf93/
...Okay, well would the connecting rods and crank be able to handle the load?...
Crank yes (same in 2jz-gte and 2jz-ge). Rods I can't say 100% for sure (since I don't work on very many n/a's), but I'd guess that for only 600rwhp: yep.
...Well I'll just get a 2JZ-GTE head. How much are the gains from a port/polish and all that?...
Whoa hold on there. You do realize the 2jz-gte head requires a totally different ignition system, and a different exhaust manifold (due to the port spacing), right? I'm pretty sure that the ports for the intake manifold are different as well...
A 2jz-gte head will flow 600rwhp no prob, with no porting & polishing.
...What is the highest comp. ratio i can go with a turbo?...
With pure methanol you could probably run 11:1 and turbo it too. Pump gas is a totally different story. It all depends how much boost you're going to run. Normally, the way you make 600rwhp with a 2JZ-GTE, you run 8.5:1 pistons, about 25psi of boost, and 100 octane race fuel.
...Thanks for the help, even though you haven't even touched on specifics your information is extremely helpful for planning out my project.
I'll get into as many specifics as I can...ask away...
Life begins at 30psi.
