Old 09-06-2007, 12:44 AM   #1
90lexus
90lexus is on a distinguished road
Originally Posted by pwpanas
Fwiw, I wouldn't let a short-term funds shortage impact your overall design in such a serious way. If you look long & hard you can find a 2JZ-GTE w/turbos from almost any Japanese engine importer (usually from an Aristo). Just mho, fwiw.
Well I appreciate your humble opinion and it is dualy noted for my next project, but I already ordered the GE and its on its way.
Yep...and it's not just lag you're dealing with - it's the varying rwhp level depending on rpm. The good part about turbos is they can make a lot of power. It feels great when that power keeps ramping up like its never going to stop. The bad side is a roadracer trying to deal with that at-times wildly varying rwhp curve.
Okay, well I really want to make it to that 600 rwhp and if it is as hard as you say to do that with out a turbo ill just have to deal with it.
I don't understand what you mean.
I was going to replace the heads and pistons, make my own intake, and get a new intake manifold, and from what i understand those are the only things that are different from the 2JZ-GTE and the 2JZ-GE.
ONLY IN THE 2JZ-GTE!!!
Okay, well would the connecting rods and crank be able to handle the load?
Depends on what you get, but likely yes regardless.
Your valvetrain is the primary consideration when raising the redline (not the pistons).
Well either way they are both getting changed.
Is that post-turbo?
Its my final output, so since I am going turbo yes, thats post turbo.
There's no such thing. There are only companies that port/polish/valve-seat-cut, etc.
Well I'll just get a 2JZ-GTE head. How much are the gains from a port/polish and all that?
10:1 is too big to turbo, and 12:1 will require race fuel.
What is the highest comp. ratio i can go with a turbo?
I can advise you better on cams after you've gone turbo.
Glad you're considering such extensive mods. Again, you've got a cool project going on here - please take lots of photos and post them all!!!
I always document my work and i definately will post all pics.
Why? Will you be driving it in bone-stock form?
Well I just want to get the project rolling before i get the turbo, so i was thinking of putting the unmoded engine in my rear-wheel-drive-converted car while im saving the money for all of the parts, so i can get one large chunk of the project out of the way and then i'd pull the engine when i got the turbo and everything and put all of the new components into the engine.
600rwhp from a normally-aspirated 3L on pump gas is asking a LOT. In fact, I'd almost be willing to bet $$$ that it can't be done without nos or a heavy dose of meth w/v.high compression pistons.
Okay, so turbo it is.
Thanks for the help, even though you haven't even touched on specifics your information is extremely helpful for planning out my project.
1990 Lexus ES250
Soon to be a Rear-Drive Supra powered monster!
90lexus is offline   Reply With Quote
