Old 09-06-2007, 12:07 AM   #1
supradaddy0803
supradaddy0803's Avatar
Engine mount adapters or new crossmember from a 89+, ignitor, intercooler, intercooler piping, intake pipe, power steering line, possibly new tach, all wireling that needs to be changed under your dash, the EA2 plug for under the hood. Also you will need downpipe, solid R154 driveshaft, antiscream cream( its a tight fit little KY would be nice. The clip is better for the swap specially if you have a pre 89 because of some differences. Also you get all the plugs and a template too look at for the swap.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
