Old 09-05-2007, 01:47 AM   #1
mrnickleye
mrnickleye's Avatar
It can be done. It has been done. The MAIN reason most people don't is......
The extra pressures in the combustion chambers on an engine that comes factory with 9.2:1 compression ratio (vs. 8.0:1 in turbo engine) will cause BHG quicker than it should.
I suppose it may last a while if you keep the boost down to about 5psi.....but why spend all the time & $$$ for a not much faster motor.
You really need larger injectors too.
