Old 09-04-2007, 12:16 AM   #14
supradaddy0803
supradaddy0803's Avatar
The R154 and the W58 are the same length I checked because they looked different to me when they are on the ground. The W58 will mount up to the back of the 1JZ but you have to change the flywheel and the bellhousing. Cheaper to just keep the R154 and buy a solid driveshaft.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
