Old 09-03-2007, 03:55 AM   #1
supraman121
I thought a bigger turbo sucked in more air or volume of air, if the turbo uses a bigger wheel or turbine, fan or what ever you want to call it i thought a bigger turbo would give me more power do to sucking in more air, if that isnt the cause then why would they make a turbo upgrade,
Nr2 you need to empty your private msgs cause i cant send you anymore msgs.
Magnaflow exhaust NO KAT
K&N Air Filter
www.myspace.com/coreyjstevens
