Old 09-03-2007, 03:37 AM   #1
Supra2NR
Supra2NR's Avatar
Originally Posted by supraman121
I want the most power at 6 to 8 psi im not going any higher i was just wondering what turbo would give me the most horsepower are 6 to 8 psi
6-8 psi is the same power, no matter what turbo you have
you can have a 16g turbo from an eclipse, or those pendant turbos that comes with the 3000gt, or a gt55r turbo from garrett, a t71 from precision,
or those gigantic turbos that sound performance uses
6-8 psi is 6-8 psi no matter what turbo u got,
now what your looking for is a turbo that spools faster,
now there are more cheaper, and more beneficial ways to do that
rather than changing your whole turbo set-up just to achieve to same boost
you can,
change the accordian hose to an aluminum one,
use all 2.5" intercooler hardpipes, all covered in heatshield,
use a 3" downpipe, catalytic converter/test pipe, and all the way to the muffler
use a bigger intercooler
now i say this, bcuz rather than buying a smaller turbo, manifold and everything that i meantioned earlier, jus to get a faster spooling turbo
which will probly spool at around 1000-1500 rpm
what happens after its not good enuff anymore, your gonna pay extra for what you should have did already,
all the mentioned mods^
all can be used with the ct26 turbo, and other turbo in case you wanna change, its jus a matter of using a diffrent silicone rubber couplers,
from my experince, when my car was still using the stock setup
i jus used a k&n filter, 3" exhaust, and all hardpipes
and my ct26 spooled at 2k,
so jus use the ct26, youll be suprised, on what you can achieve with that turbo
