Old 09-01-2007, 05:12 AM   #23
Spudboy
Spudboy's Avatar
Originally Posted by Spudboy
I wasn't sure if you 'say' bolts but really meant studs with nuts. I was not offered a choice so I didn't know I had one. At this point I would prefer bolts. So far these studs and nuts are a real pain. I need to look at some other threads for some ideas on the install.
My guess is the advantage to stud/nut combo is better and more consistant torque values. It will be worth it if I don't ever have another BHG.
Once I figure out this obsticle I will explain later.
Hey Bill UK...or anybody whose done it...I have ARP studs. I thought a good idea would be to install studs first then gently lower the head on. Turns out this doesn't work as the heater union hits the firewall lip. I don't think I can remove the union then fit it back on later as the big 32mm socket wont fit. Now the dilema is can I install these studs after I seat the head...not much room to hand tighten the studs well. How did you do it???
