Old 08-31-2007, 09:36 PM   #1
jadeanthony
jadeanthony is on a distinguished road
not being a mechanic, I assume it is because it is an uneven surface correct? But if the guy took the head off to replace the gasket, wouldn't he have seen that the surface looked like this and therefore would have had it ground or whatever they call it...to give it an even surface............did this guy just cut corners and charge him big $$$$ and not do the job properly????
Originally Posted by ddmcse
look at my block and you can see why just replacing the headgasket might not be good enough
http://www.ddmcse.com/turbo/images/process/0hrs.JPG
jadeanthony is offline   Reply With Quote
