Thread: Codes 25,26,51!
Old 08-21-2007, 09:51 PM   #1
supradaddy0803
supradaddy0803's Avatar
The o2 sensor isnt gonna make you run hot unless you are running really lean. Then you would see the manifold glowing but if you had that I am sure you would have said so. The only thing I see that comes to mind is there isnt enough of a signal getting to the computer to give it the proper signal so it is freaking out. I know there is a bunch of people that use different o2 sensors because of they are better for widebands but to that effect I am not sure.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
