Old 08-21-2007, 03:26 PM   #1
mrnickleye
mrnickleye's Avatar
Originally Posted by dcrusupra
Your idle will fluctuate, maybe stall, while you turn the wheels while idling
NO. That hose connection on the accordian hose is so the air going into the power steering idle-up valve is 'clean'. If the hose is not hooked up, unfiltered air will be sucked into the accordian hose, AND into the P/S idleup valve (and on into the throttlebody). dirt=bad
