Old 08-21-2007, 07:57 AM   #1
Supra2NR
Supra2NR's Avatar
Originally Posted by supraman121
Would you be able to do a twin turbo setup on a 7mgte, is the 1jz ecu compatable with the orginal 7mgte ecu plugs/plugins, and does the 1jz manifold work on the 7mgte engine?
I know a shop that has a twin ct-26 setup on a 7mgte engine
on a older model corolla that runs 10.0 all day
if you want i can get a pic if you need it
