Old 08-19-2007, 01:12 PM   #1
f00g00
Did you try connecting it to the factory tach wire? The schematic says its the IG- wire on the igniter. The same wire goes to one of the pins on the check connecter apparently which is marked IG- which is the same so you could run a wire from that to test the new tach before doing any cutting.
