Originally Posted by tone loc
if the block surface is in good condtion then you dont have to get it resurfced. get arp head studs. i think you torque them to like 75-80 ft/lbs
If you like to keep blowing your headgasket do what he said.
To use a MHG you need to have an ABSOLUTELY PERFECT block and head. If theres the smallest imperfection, it will blow. You need to have the head machined and the block machined and lapped. Just go with a stock headgasket. I've been running 10 psi since april on the stock headgasket. No problems what-so-ever.
