Old 08-13-2007, 09:41 PM   #1
supradaddy0803
supradaddy0803's Avatar
Ok first off I am not knocking the 7M's at all but I did a 1JZ swap and I love the difference in the car all together. The 1JZ has a factory MHG shares so many things with a 2JZ and is twin turboed to boot. Of course there is a lot more modification but with a little time and pateince it all comes together. But if you dont know much about the swaps then I would go for a 7MGTE swap because you will have so much of a easier time with it. As for all of the parts you will need sometimes if you find a clip you will get everything and not have to peice everything together but 7M clips are really hard to find and cost a little more than just the motor.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
