Old 08-13-2007, 02:32 PM   #5
mrnickleye
mrnickleye's Avatar
Talking Facts are out there
Googling around brought these sites up. Check them out.
http://www.parker.com/ead/cm2.asp?cmid=9087
http://www.parker.com/ead/cm2.asp?cmid=9093&
The tires run cooler with pure nitrogen. While an air filled tire's pressure will increase 5*-10* when hot, a nitrogen filled tire will increase 1*-5*.
http://www.parker.com/balston/English/coolrunning.pdf
[quote]
"Sheehy and his technicians service their trucks as they come in off the road, and they’ve been checking tire pressures consistently as part of their nitrogen test. According to Sheehy, every truck leaves home base with their drive tires inflated to 85 pounds. “If you check the tire pressures right off the road, a normally aired up tire will come in at between 90-95 pounds consistently when they’re hot. The nitrogen comes in between 85 and 90 pounds. It’s more stable, which means they’re running cooler".
But for me...since 80% of my driving is short trips around town, I use regular air, and I tend to wear the tread out quicker than the rest of the tire...and I do check and top up my air pressure (36psi) regularly.
