Old 08-13-2007, 01:55 PM   #4
finaltable
finaltable is on a distinguished road
Originally Posted by 4ageBT
It makes your tire pressure constant no matter the road temparature.
Nope. All gases, regardless of molecular composition, behave according to pv=nrt (pressure*volume=number of moles * constant * temperature.) It is IMPOSSIBLE to have constant pressure under rising temperature without changing one of the other factors at the same time. Since the inside of a tire is a roughly constant volume, unless you are planning on leaking gas when the temp goes up the pressure WILL increase.
Current ride: Not a Supra :-(
finaltable is offline   Reply With Quote
