Thread: New Radiator?
Old 08-06-2007, 07:57 PM   #1
IHateHacks
IHateHacks's Avatar
Yeah you should be good. As long as you are not overheating. After you put the new radiator in watch the level in the overflow. Make sure you are not "losing" coolant. I'd run another block test if I were you. You have to drain the coolant anyway, you might as well test it again.
