Old 08-05-2007, 02:00 PM   #1
j3pz
the turboed civics ecu depends if they did a swap or kept the d16. if they did a b-series swap they need a b-series ecu, a k-series swap they need a k-series ecu.
the fuel maps are different for the supra n/a and supra turbo. so at a specific rpm the cars recieve a different amount of fuel. THE NA ECU WONT WORK FOR THE TURBO WITHOUT A A/F CONTROLLER. if you wanna go blow up your fresh conversion go ahead... you will run lean like a bitsh and motor go boom
as for the a/f controller, get the turbo one, it will be a turboed car right???
ninja edit 2: if you dont wanna listen to me, just go to a local shop and ask them
