Old 08-03-2007, 09:56 PM   #3
D_Train
D_Train is on a distinguished road
Originally Posted by SupraDupra
The little yellow box is connected to the harness that powers your tailights. Moisture gets in there and messes it up. Mine is bad too ,but as long as the tailights keep working I'm ignoring the problem. Not sure where to get the replacement ,but if you pop the access panel off from behind the drivers side light you should see it in there.
Yah. Its wierd tho, the light doesn't go on until I press the brakes....
D_Train is offline   Reply With Quote
