Old 06-24-2005, 10:00 AM   #1
ddmcse
ddmcse's Avatar
thats what the turbo was made to do ..the trick is going to be getting you car to accept 10 lb all the time .
currently with fuel cut off i can get about 10 ish pounds depends on the weather and the position of the sun and moon ( the turbo will produce much more but toyota says nope party's over)
if you have the engine apart surface the head and block for a metal head gasket
300+ RW HP Dyno run,
Blown HeadGasket info
My Supra KiXGaS
