Originally Posted by abhattan
I have the same problem, but my cap is good. I did a compression test and got 110psi on #1 cylinder, the rest was at 150psi +/-4psi. What could it be?
You need a rebuild bud. It shouldn't go below 120 psi nor should it be above a 15 psi difference among the 6 cylinders.
