Old 07-31-2007, 03:58 PM   #2
D_Train
D_Train is on a distinguished road
Originally Posted by dcrusupra
There is probably a small leak in a hose somewhere. The temp gauge going up and down is probably a loose connection on the temp housing. Did you check the hoses behind the head? Those are a common trouble area as far as coolant hoses go.
I checked all the hoses. Dye'd the coolant so it would show under a black light and saw nothing leaking at all. It never leaves coolant on the ground when parked. Could the loose temp housing cause me to loose coolant?
D_Train is offline   Reply With Quote
