Originally Posted by ethan12510
i dont have to?
here's the deal
1)if you lock with with the power door locks or manually with the key in the ignition,
if your sensors are still working right
it wont let you lock the door at all, itll unlock the door as soon as you lock it
2)if you use the power door lock from the inside (as in you press the button)
you dont have to hold the handle up when you close it
3)if you manually lock the door (as in you used your finger to push the thing)
you will need to hold the handle up
best case scenario, jus use the key
i never had a supra with the power locks working properly
