Thread: Clutch Problem
Old 07-30-2007, 09:50 AM   #1
f00g00
Stock components?
Try pumping the pedal a few times, if that helps then the master cylinder or the clutch release cylinder might be worn out. You said the car sat for 11 years. Most mechanical components need to be exercised once in a while to stay in working order especialy components with seals in them. I'd get new ones, they aren't that expensive.
