Thread: turbo swaps
Old 07-27-2007, 03:06 PM   #1
Supra2NR
Supra2NR's Avatar
Originally Posted by HUSSEY
will that meen i have to change the wiring harnes. I'm sure i have to change the ecu. but will all of this "plug and play" with the na engine.
one more question about this were an i fine this engine and what are the average cost and whats the horse power.. thanks or all the help guys
well everything with the 7mgte swap would be a plug and play install
but if ur getting the 7mgte, u better be sure to get the little things too
ie: coil pack, igniter, harness, ecu, power steering mount,
intercooler, throttle body housing, TB cable
and try to get the r154 trans too, the NA trans will bolt up, but
the 154 is more robust, and can hold more power
