Thread: loud turbo
Old 07-26-2007, 08:40 PM   #10
west_side_supra
west_side_supra's Avatar
ok so i have a freind that works at waltz and i had him test a buch of stuff.
pressure test = OK no leaks didnt go below 6/lbs of pressure it held
block test = OK - didnt change colors
radiator cap test = 10/lbs OK
diagnostics = needs to be flushed air bubbles in the heater core
does this sound still like a BHG? or do you think it is right, because i know it has bubbles in the heater core because its doing the waterfall sound
he also mentioned that the coolant was at boiling point but that is probably because there is more water than coolant. didnt feel like spending a but load of money on coolant every week :O)
7MGTE - 500hp never dyno'd
fidenza cam gears
