Old 07-25-2007, 03:17 PM   #1
supradaddy0803
supradaddy0803's Avatar
The sensor is actually in the overflow tank so if the overflow is not as full as it should be then you need to add some water to the over flow.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
