Old 07-25-2007, 02:41 PM   #2
Supra2NR
Supra2NR's Avatar
Originally Posted by 88Supra86
blah this is going to be very tedious... but i dont think it can be as much as a a problem then an 86 camaro. actually it probably is worse with my luck haha. ok well if im gonna do this i might as well spend some money on a better clutch then the stock clutch any suggestions on a clutch?
it all depends on your application,
your still stock right?
a stage1 act clutch should hold you jus fine
but if it was me, i would use a exedy trible carbon clutch
with a heavy pressure plate
and lightweight flywheel
