Old 07-23-2007, 08:11 AM   #1
f00g00
The problem with the speedo cables is that if they freeze up they can ruin the gear in the transmission. This gear is made of plastic and gets rounded out in the middle so it is probably bad. You can pick one up at the dealer for fairly cheap, mine was less that 30 dollars and came with a C clip and the oil seals. I had a mechanic crawl under there and change it so I didn't see how it was done.
