07-17-2007, 08:47 AM
#1
have you done tune-up, lately? have you check on the following: failed fuel pump, ignition module or broken overhead cam timing belt, battery? it would be best to check all your toyota parts to know what might be causing the problem.. keep us posted of what other things did you find out.. good luck
