Old 07-17-2007, 03:02 AM   #6
mrnickleye
mrnickleye's Avatar
(QUOTE) your fan clutch is the aluminum piece between your fan and water pump. to test it get the car hot and turn it off, you should not be able to turn the fan.
You WILL be able to turn the fan. It should be firm, and not 'free-spin' more than 1/2 a turn. New clutch is approx $90.
Do a block-test to make sure your HG is sealing good. You descriptions sound like BHG.
