Old 07-17-2007, 01:27 AM   #5
supramacist
supramacist's Avatar
If he's running the ac and the fans aren't functioning, he may overheat.
Now...., coolant. You can fill the rad with straight coolant. You will overheat more quickley. You want to maintain the 50/50 mix. Unless you live somewhere like alaska or the north pole or some shit.
Damn I just sat down for a check and I haven't the time to go into it and I want to think about those questions.
But straight coolant will mess your shit up. And also..., only distilled water goes into the rad unless you want to rust it out from the inside.
I'll post up again.
I have to split right now.
