Originally Posted by plaaya69
I was looking at your Sig and is this your jasper motor with 868 Miles that you are replacing the HG?
yes i have a prior thread if you care to check it out. Jasper will not cover the manufacture defect of the headgasket failure and the ring falure in cylenders 5 and 3. I pulled the head off in about 3 hours (damn iv been doing this too long) found out there are scores on cylender bores 5 and 3. I checked it with an inside-mic and i see about .0023 difference from standard bore. I can easily rebore that in the shop. Its only 23 ten-thou so i might even be able to hone that out. Heres my parts list im going to throw together over the next few weeks.
-868 Miles on new jasper engine
-All hard pipes
-0.57 trim ct-26
-greddy type S
-greddy profec b
-apexi ride high 7 way adjustables
-eibach springs
-slotted rotors
-mkIV TT rims (front)245/45/17 (rear)285/40/17
-targa
-greddy turbo timer
-egr eliminated
-3" turbo back, no cat, no resonator, Apexi N1 back.
-n/a cams
Theres others ill think of later.
