Old 07-13-2007, 12:53 PM   #4
f00g00
Are those plugs for the injectors from the 86.5 harness or the cut harness?
The injectors look yellow to me so might be the JDM ones which won't work on a US harness. Take a look at this link and you can see the difference between the JDM plugs and US plugs.
http://lextreme.com/Injector%20data.htm
US uses plug F and JDM uses E for 7MGE.
If you have the yellow ones you will have to get a set from a junkyard and don't forget to put new O rings on them.
